UMX Beast 3D BNF
  • RSS
    • Dec 2013
    • 6055
    UMX Beast 3D BNF
    UMX Beast 3D BNFOverviewThe E-flite® UMX™ Beast® 3D aircraft is a totally new experience in all-out 3D flight capability and satisfaction from an amazing aircraft that doesn’t need any more space than a small park, a yard or an indoor gym to be enjoyed. Enhanced with the AS3X® System, the UMX Beast 3D plane is specifically set with an aft CG and large control surface deflections for maximum maneuverability. However, instead of handling that feels super sensitive, the UMX Beast 3D plane, with the AS3X System, flies ultra smooth, even in conditions considered windy. Plus, you get locked-in precision and the outstanding control authority necessary to perform 3D more confidently. Designed by aerobatic world champion Quique Somenzini, this authentic UMX re-creation of the full-scale Beast delivers precision aerobatic and 3D excitement with the kind of stability and authority more in common with aircraft many times its actual size. And you get all the benefits without having to spend a lot of time programming. No mixing is required—just add your Li-Po battery, bind to a basic DSM2®/DSMX® airplane transmitter setup, and the UMX Beast 3D plane will instantly offer you the best flight experience possible.Product SpecificationsWingspan: 14.7 in (374mm)Overall Length: 15.7 in (400mm)Wing Area: 83.8 sq in (54.2 sq dm)Flying Weight: 2.54 oz (72 g)Motor Size: BL180 2500Kv brushless outrunnerRadio: 4-channel minimumTrim Scheme Colors: Black, Red, SilverCG (center of gravity): 19mm back from leading edge of bottom wingWing Loading: 3.4 oz/sq ft (1.01 g/sq dm)Prop Size: 5 x 2.75 inchRecommended Battery: 2S 7.4V 180mAh Li-PoControl Throw (Ailerons): Low: 70%, 0% expo; High: 100%, 0% expoControl Throw (Elevator): Low: 70%, 0% expo; High: 100%, 0% expoControl Throw (Rudder): Low: 70%, 0% expo; High: 100%, 0% expoApprox. Flying Duration: 5 minutesMinimum Age Recommendation: 14 yearsExperience Level: IntermediateRecommended Environment: Indoor/OutdoorIs Assembly Required: NoMed i prisen på denne flotte modellen får du en 120cc Hangar9 Beast til den nette sum av 45.000!*ustartet* modell proppet med high-end utstyr.Product SpecificationsWingspan: 89.0 in (2,260mm)Overall Length: 86.0 inches plus spinner lengthWing Area: 2,490 sq in (161 sq dm)Flying Weight: 26.0–28.0 lb (12.0–13.0 kg)1 x Hangar9 Beast7 x JR DS8921HV 2s LiPo 36.5kg 72g (Alle rorflater)1 x JR DS8925HV High Voltage Servo (Throttle)2 x 6,6V 2100mAh - 5C - Hyperion LiFe Receiver Pack (Rx)1 x 6,6V 1600mAh - 5C - Hyperion LiFe Receiver Pack (tenning)1 x Desert Aircraft 1201 x Futaba SBS-01T Temperature Sensor 18MZ 14SG1 x Futaba Optical RPM Sensor Unit Telemetry S.BUS21 x MTW Canisters Complete set for Beast1 x DPSI 2018Servoer har kun hatt strøm for sentrering.Motor har aldri vært startetGjenstår å montere wire på hale + et par servokontakter.Produsentlink: http://www.hangar-9.com/Products/Def...050Byggeblogg: https://www.modellflynytt.no/showthr...angar9-Beast-2
    More...
