Mini VBar "Blueline" 5.3
  • RSS
    • Dec 2013
    • 6055
    Mini VBar "Blueline" upgrade 5.3 Ca 4 mod g Mini VBar "Blueline" 5.0 Express (free upgrade to 5.3 Express )The Mini VBar is the world’s smallest and lightest 3-axis virtual flybar system. It is designed to fit most electric helicopters. Despite its small size, the Mini VBar is equipped with top-quality sensors and will thus satisfy the highest performance expectations. Programming is done via a control panel, or via USB using the PC software. A special feature of the Mini VBar is the option to use it in conjunction with one or two 2.4 GHz satellite receivers (you may choose from various brands). This feature renders it unnecessary to use a primary receiver. It is also possible to connect the Mini VBar to a receiver in the conventional way. MiniVBar operates with the following satellite receivers: Spektrum, Fasst, Jeti Duplex. The all new Mini V-Bar can now be used in all electric model helicopters with only a few limitations: Do not use the Mini V-Bar in the following types of helicopters:- Scale helicopters- Helicopters with multi-bladed rotorheads (3+ blades)- Custom built helicopters.3-Axis Gyro SystemDimensions: 28 x 37 x 13 mmWeight: 11 g
    More...
