Flyklar Spitfire kompositt 30cc
  • RSS
    • Dec 2013
    • 6055
    Meget pen og flyklar Top RC Model 30cc Spitfire med vsp på 205 cm selges. Modellen er i helstøpt glass/kompositt, elektrisk understell, cockpit,Saito FG 36, metallgirservoer og både custom 2 og 3 blads spinner. Den har også fått litt weathering, scoop og hjul dørene er nå montert.Kun å sette inn mottaker!Settet med retract og 2 spinnere kostet meg eksakt 14 000 levert hjemme. Selges til foreslått pris, dyr modell men forseggjort og flyr som en drøm!I tillegg står det en Saito FG 36 firetakter installert, metallgirservoer og Life batterier i den.Meget lettflydd og fin modell.Min maiden flight: https://www.youtube.com/watch?v=9cD3...escription:Top RC Models comes to the US with the 81" 1/5 scale MKIV Spitfire. This model is a reproduction of the Canadian Johnny Johnson who flew with the Royal Air Force in WWII. This Spit is the first of many new planes that is considered by experts to be a unique game changer. No plastic covering, the plane is constructed with full composite "Sandwich Technology" bringing the lightest airframe ever introduced. The Fuselage weighs 3 lbs. the wings,with aluminum tubes in them weighs 2 lbs. The entire airframe assembled with a 35cc gas engine and retracts will be less than 20 lbs. We estimate around 18. This new composite technology uses 45% less resin than it's closest counterpart in the industry. Yet, the skin is rigid, strong, and can hold up to the performance of a strong 35cc or electric power plant. The model offers the following features:1. Full composite construction , sandwichrumpf by Airex, balsa & epoxy.2. All surface prepainted,decals applied and clear coated3. Scale cockpit, scale exhaust included.4. Detachable Scale gun set and antenna included;5. Detachable main wing and tailplane for easy transportation;6. Removable hatch on fuselage for easy access into the plane and change accessories;7. Functional splitflaps for smooth landing.8. High quality CNC Alum. push rod includedSPECS:Specification:Wing Span: 2058mm/81inLength: 1715mm/67.5inFlying Weight: 7.6kgWing area: 74.95 dm2Engine: 35cc
    More...
