Selger mitt Gaui X3 da hobbyen dessverre har blitt nedprioritert i det siste. Helikopteret er bygget av meg, det gjenstår kun oppsett av gyro og montering av satellitter. Det er også bygget om til belte-drift. Alt som følger med er helt nytt og ubrukt. Nypris ca. kr 10.000.Utstyr som medfølger og/eller er montert:- GAUI X3 Basic Kit (CNC Tail Rotor Grips) ($299 med 4 x servo)- 3 x ServoKing DS-995- 1 x ServoKing DS-995i- iKON Flybarless System with CRIUS MWC Multiwii Bluetooth Module "IKON" (iKON1001-CRIUS) ($234.99)- Align 460MX Brushless Motor(1800KV) S6 version ($50)- Hobbywing Platinum 50A V3 Brushless ESC ($55)- 2 x Spektrum DSMX Remote Receiver (SPM9645) (kr 1000)- Lemon DSMX sat ($10)- 2 x 360 3G Carbon Fiber Blades ($50)- RJX Vector Green 360mm Premium CF Blades-FBL Version (XL Version) ($33)- 2 x Lion Power Lipo Battery 22.2V 1300Mah 30C MAX 45C T Plug ($50)- GAUI X3 Tail Belt Conversion kit - 216212 ($26)- GAUI X3 Replacement Tail Belt 522MXL - 216218 ($6)- GAUI X3 GF Fin and Tail (Neon Yellow) ($10)- GAUI X3 Main Blade Grips Parts UPGRADE Pack - 216343 ($5)- GAUI X3 Main Gear Hub - 216114 ($12)- GAUI X3 Replacement Tail Belt 522MXL - 216218 ($6)- X3 Main Rotor Spindle Shaft x 2pcs (for CNC blade grips) ($6)- X3 Tail Rotor Blade Set (62mm) ($5)- X3 GF Fin and Tai l( Bright Yellow ) ($10)- X3 Tail Boom * Torque Tube Set ($10)- 2 x Tail Drive Belt (H50045) ($13)- X3 Main Shaft 125mm x2pcs (216201) ($10)- LYNX Ultra CNC Tail Boom Supports - RED - GAUI X3 ($19)- LYNX CNC Slant Main Gear 131T - GAUI X3 ($1- LYNX CNC Precision Swash Plate Leveler - GAUI X3 ($15)- LYNX High Performance PRO 3D Tail Blades 68mm NEON YELLOW - GAUI X3 ($7)- LYNX CNC Precision Swash Plate Leveler - GAUI X3 ($15)- LYNX Steel Pinion Slant 11T Mod 0.6 X 3.50 mm Motor Shaft [LX0706] - GAUI X3 ($5)- LYNX Steel Pinion Slant 12T Mod 0.6 X 3.50 mm Motor Shaft [LX0707] - GAUI X3 ($5)- FUSUNO Rocket Fiberglass Airbrush Canopy - GAUI X3 ($30)- Landing Skid ($6)- Landing Skid-Fluorescence Yellow ($7)
