Selger en fin elektroseiler av type Kunai fra Great Planes. Den er ferdig satt opp med 1400kv børsteløs motor og 30A regulator (2-4S) . Dette er en sprek kombinasjon som trekker modellen vertikalt med god hastighet. Modellen fremstår i utmerket stand og det sitter 4 stk microservoer montert. Selges kr 1900 . Pris hos Elefun ca 3200 kr (+frakt)Passer glimrende til 3S lipo ca 800 – 1200 mAh. *Kan sendes i sikker forpakning for kjøpers regning (Norgespakke).Kontakt e-mail: rotel123@hotmail.com eller tlf: 41325920Beskrivelse fra produsent:Aggressive climbing...exciting, high-speed aerobatics...soaring. The Kunai offers the best of all worlds! It does all sport aerobatic maneuvers and allows the use of optional spoilerons. The Kunai’s designers kept the parts count low for quick, straightforward final assembly. Whether you choose the ARF or the Rx-R version, you'll have a great-flying model that looks awesome — and is ready for fun FASTFeaturesConstruction: Fiberglass fuselage for high strength and low weight Tail Boom: Carbon fiber Wing: One piece, built-up, factory covered Canopy: Removable for battery exchange Controls: Ailerons (2-servos), rudder, elevator and throttle Brushless Motor: Factory installed 28x31mm 1400kV outrunner Propeller: 8x6 folding Spinner: (32mm) diameter Hardware: Included IncludesFiberglass fuselage, main wing, tail section, hardware package, decal sheet and instruction manual SpecificationsWingspan: 55" (1395mm) Length: 36" (915mm) Weight Range: 18.4-19.7 oz (520 - 560 g) Wing Loading: 9.4 - 10.1oz/sq ft (29 - 31g/sq dm)
