Volantex Sbach 342
  • KennethLNOR
    • May 2014
    • 52
    Volantex Sbach 342
    Har en Volantex Sbach 342 liggende i original esken. Aldri fått tid til RC hobbyen.
    Rettelse: Trudde jeg hadde RTF modellen, men det er PNP modellen.
    Selges for 1200kr.
    Kan kontaktes på 48322568
    Features:
    Good 3D manuaver
    Light and durable EPO construction
    Easy to assemble
    Specifications:
    Wingspan: 1100mm (43.3 in)
    Overall Length: 1115mm (43.9 in)
    Flying Weight: 1100g
    Prop Size: 1260 propeller
    Motor Size: 4023 Powerful brushless motor
    Speed Control : Easy-Plug 40A Switch-Mode BEC brushless ESC
    Servo 9-gram Servo * 2pcs, 17-gram Servo*2pcs
    Recommended Battery: 11.1V 1800mAh ~ 2500mAh 25~30C Li-Po (not included)
    Charger: 3S LiPo balancing charger, 0.5A (not included)
    Flaps: No
    Retracts: No
    Radio: 2.4Ghz 6-Channels (not included)
    Minimum Age Recommendation: 14 years
    Experience Level: Beginner
    Recommended Environment: Outdoor
    Assembly Time: Less than Half Hour
    Is Assembly Required: Yes
