Kraftig esc for helikopter fra 500 klassen og oppover 6-12S lipo. har innebygget antispark så du slipper gnist ved tilkobling. Brukt til en flyving....!Ny pris £154.99Specification Output :Continuous Current 120A, Burst Current 150A for 10 seconds Battery Cell :18-38NC/6-12Lipo Weight :145g Size :55x72x17mm(LxWxH)Features: Supports high RPM motors,can be used with most of the motors in the rc market Secondary sub-menu setting ,is easier to be programmed Advanced Governor Mode ( has the B-Series ESC to keep the motor speed even though the load is changed) More optional motor timing Setup and soft acceleration start ups ( make the motors run smoothly) Super smooth and accurate throttle linearity Power arming protection (prevents the motor from accidentally running when switched ON) Auto throttle shut down in signal lose situation Safety thermal over-load protection, when the temperature of ESC exceeds 110 deg C,the ESC will reduce the output power to allow it to cool Use new generation of the MOSFET to ensure ESC's heating low,supporting biggest Peak current and higher reliability New Advanced programming software Anti-Spark feature. When connecting your ESC, first connect the large Black wire then the small red anti-spark wire then the large red wire. This will eliminate the large spark on power connection issue normally associated with HV ESC's.BEC - NoneContinuous - 120A (Burst - 150A)EnErG Pro B-120 OPTO HVLipo Cells - 6-12 (NiMH Cells - 18-3Program Card - 4404970Programmable - Yes (Manually or by Program card not included)Size - 55x72x17mmWeight - 145g
