Strøken Tuff Trainer fra HK. Liten og robust trainermodell.Lite brukt.Du trenger mottaker, batteri og sender i tillegg.Dette er kun modellen med motor, servoer og regulator (esc)Wingspan 890mmLength 745mmFlying Weight 320g~360gESC 15-20A w/BECMotor 2208 1400KVServo 8g x 4The Hobbyking Tuff Trainer is the ideal choice for the new RC pilot, a trainer needs to have certain qualities to be really good at the job it is intended for, so it is perhaps fortunate that supermodel good looks is not one of them, what it lacks in glamour, this model more than makes up for in performance, toughness, practicality & value for money.The Tuff Trainer is exactly that, a combination of almost un-breakable EPP foam, band secured wing and carbon fibre spars means that, should the worse happen, this model will bounce and then bounce back for more. In the unlikely event that you do manage to break it, a little cyano glue and a few minutes patience will be all thats needed to have you grinning again.The Hobbyking Tuff Trainer is Plug-and-Fly(PNF), so motor & ESC are pre-installed. Note that the prop mounts with a prop saver just in case you have a less than perfect landing. Good quality 8g servos are pre-installed and quality hardware tops of the list of essential must haves that are included with this kit. A trainer should be easy to fly; the combination of high angle of dihedral and high lift thick section wing make the Hobbyking Tuff Trainer a very stable, forgiving flyer, with excellent slow fly capability that does not lack the single most important factor.............FUN!
