Selger med denne samt RA 02 TL diversity satelittantenneThe RG731BX from JR is a DMSS Full Range X-Bus receiver. Instead of Pulse Wide Modulation (PWM), this new X-Bus system utilises JR"s own serial bus data to communicate with X-Bus products (such as servos). Thus, control signals are sent in a serial manner to all channels, with individual servos recognising their own data from the receiver.The RG731BX can still be used in conjunction with a channel decoder (XB1-CPR) in a serial connection or standard servos can be plugged directly into the PWM ports of the receiver (avoiding the X-Bus port). The RG731BX has 7 ports for PWM (standard servos) and 1 X-BUS port.The RG731BX package includes the receiver main unit, RA01T remote antenna and a 150mm RG Cable. You will also receive a bind plug and operation manual. This is a highly-capable receiver from JR that will be an asset to advanced pilots looking to control large numbers of servos. Order yours now.Features:Cross-modulation restricted with DMSS; minimising inter-modulation interferenceTelemetry system capable of feeding back informationSecure and precise communication with coaxial and remote antennasLEDs confirm receiver operationSupports transmitters' fail safe settingX-Bus port
More...
More...
