Zdz 180b2rv-j 2013
  • RSS
    • Dec 2013
    • 6055
    Zdz 180b2rv-j 2013
    Vurderer salg av denne ekstremt gode motoren. Den har vært 2 turer i lufta siden den var ny, og det var stort sett bare putring på 1/3 gass. JMB canistere/bend med røyknipler. MUFFLER MB 105-80-300 K 10115 HPAL-ZDZ 160-J "M" - SMOKE Perfekt motor til Pilot-RC 40% Decathlon bl.a.! Two stroke 180ccm opposed twincylinder model gas engine with procesor controlled ignition unit. Fuel intake of this engine is managed by rotary valve which contrary to the usual reed valve system allows much more precise controll over the timing and same time brings much longer lifetime without need to change reed valves. Displacement:184ccm Weight:3500g Bore:50,5mm Stroke:46mm RPM range: 1000-8500ot/min Ignition :Processor controlled 4,8-7V Fuel mixture N95+rec. oil:1:35 Recomm. twinblade props:32x12, 32x14, 33x12 Recomm threeblade props:30x13
    More...
