Specs: Cont. Current: 25A Burst Current: 50A BEC: 5volts / 2amps Weight: 42.5 Gram (including wires and plugs) Battery Plug: XT-60 Motor Plug: 3.5mm Bullet Connector Programming Options: Brake (OFF/ON). Cut-off Type (Soft-cut/Cut-off). Cut-off Voltage (Low / Middle / High ). Start Mode (Normal / Soft / Very Soft ). Timing Mode (Low / Middle / High). Cell (Auto, 2S, 3s, 4S). Note: Programming can be done via the Optional programming card. See related items below. This ESC requires the user to set the throttle range on installation. Please download the manual for further instructions.
