Futaba R7018SB mottaker
  • RSS
    • Dec 2013
    • 6055
    Full range Futaba 2,4G FASSTest mottaker med 18 kanaler.Medfølger i esken * R7018SB mottaker * On/Off bryter * To female Deasn/T-Plug kontakter * Krympeplast * Skrutrekker Spesifikasjoner * FASSTest 2.4GHz (18ch/12ch mode) Bidirectional communication system * FASST 2.4GHz (Multi-ch mode) * Dual Antenna Diversity * Dual Battery system with ultra T-Plugs * Dimensions: 54.6 x 40 x 16 mm * Weight w/o case: 42 g * Power Requirements: 6.0V to 7.4V (Voltage Range: 4.8 to 8.4V) * S.BUS/S.BUS2 compatible ports * 18 PWM Output ports * Battery Failsafe Voltage * Extra Voltage Port: 0~70V DC * Resolution: 2,048steps * Speed (Frame Rate): 6.3ms / 15ms - FASSTest (12ch / 18ch) 7ms / 14ms - FASST (High Speed/ Normal)
    More...
