Freewing Yak 130 (8S setup)Nyskick !
  • RSS
    • Dec 2013
    • 6055
    Wingspan 1200mm / 47.2in Length 1500mm / 59in Flying Weight 4000g / 141oz CG (Center of Gravity) Power System 4075-1250kV Brushless Inrunner Motor Electronic Speed Control 150A, 5A UBEC, EC5 connector Propeller / EDF 90mm metal housing with 12-blade impeller Servos 9g and 17g digital metal gear servos Landing Gear Nose and main gear have electronic retracts with shock-absorbing aluminum struts Required Battery Two 4 Cell 14.8V 5000 mAh LiPo Batteries with EC5 connector Required Radio 6 Channel (7 channel for wind break) Ailerons Yes Elevator Yes Rudder Yes Flaps Yes Lights Yes Hinge Type Nylon hinges Material EPO Foam
    More...
