Eagle A3 Super II gyro
  • RSS
    • Dec 2013
    • 6055
    Selger en Eagle A3 Super II gyro med ekstern programmeringsenhet. En haug med modus og settes opp på 1 minutt. Selges da jeg standardiserer på Jeti sine oppsett. Bildet er kun for illustrasjon 32-bit MCU, 3-axis gyroscope and 3-axis accelerometer. One-click rescue, One-click hover. 6 flight modes: off, normal, 3D, auto-balance, auto-hover and user defined mode. 2 stick control modes: Manual Mode(MM) and Auto Mode(RR/AR). Various wing types: 1AIL+1ELE, 2AIL+1ELE, 1AIL+2ELE, 2AIL+2ELE, delta-wing and V-tail. Separated gain setting and gain rate for each flight mode, remote master gain control. Compatible with all standard receivers or Futaba's S.Bus/S.Bus single-line receiver. Up to 333Hz servo operating frequency, compatible with all analog and digital servos. 5-level response rate setting allows you to use it on gas-powered planes. H.V(8.4V) receivers and servos supported. Flat or upright mounting orientations. A program card helps you setting up the controller more easily in the field. New designed config GUI allows you upgrade the firmware online Flight Mode A3 Super II provides 6 different flight modes. You can assign your desired flight mode for each position of the 3-way switch using the config software or the programming card. If the input [MOD] is not connected, system will always default to the mode that has been assigned to Position-1. Gyro Off Mode Choose this mode to disable the gyros for all channels. The plane will be completely under the control of the radio. The plane will go back to its previous performance when operating it in this mode. Usually it is only used to test. Normal Mode Normal mode is the most basic application of the gyro. In this mode, the gyro will sense angular velocity on each axis and make a momentary reaction. The normal mode is suitable for all types of fixed-wings, it can effectively improve the stability of your plane specially on a windy day. 3D AVCS Mode The AVCS mode is an advanced application of the gyro. By adding an integral algorithm to the gyros, the controller will try to lock the plane to its previous attitude if there is no command sent from the transmitter in a flight. This mode can effectively help you to accomplish such hard actions as hover and knife edge. But this mode is designed especially for the 3D planes, it's not suitable for the planes those not designed for 3D flight. Auto-balance Mode The auto-balance mode is designed for the new beginners or the FPV applications. When operating in this mode, the controller will command the plane to maintain level flight automatically when you release the sticks. When switch it to this mode from any other modes in an emergency, the plane will recover to the level flight automatically, which we call "one-click rescue". Auto-hover Mode The auto-hover mode is another form of the self balance ability of the controller. The only difference is that the correction from the gyro will be applied to both pitch and yaw axes, to keep the plane always vertical. When switch to this mode, the plane will lift its nose and start to hover automatically, which we call "one-click hover". User Defined Mode This mode allows you to select different mode for each axis, from normal , 3D or gyro off mode. Main Controller: 32-bit MCU Sensor: 3-axis gyroscope and 3-axis accelerometer Gyroscope Scale Range: ±2000 dps Accelerometer Scale Range: ±4g Input Signal: Standard PPM with center point 1520uS, or S.Bus serial data Output Signal: PWM max frequency 333Hz, 1520±500uS Input Voltage: 4.8V ~ 8.4V Operating Temp: -10 ? ~ 50 ? Size: 43×27×14mm Weight: 10g (excluding wires)
    More...
