Ikke helt upassende at denne dukket opp til omtale når Warbird Weekend nærmer seg.
Link til Smallsize!
Spesifikasjoner fra Parkzone:
Compared to the Spartan look of most World War I airplanes, the smooth, rounded fuselage and flowing lines of the Albatros D.Va made it one of the more daring designs of its time. The ParkZone team has recreated this Western Front warrior with an impressive level of detail and equipped it with a potent 480-size brushless motor. Some of the more notable scale details include a molded recreation of the 180hp Mercedes D.IIIau engine, accurately modeled wing struts and a pilot figure complete with flying scarf.
Wingspan: 42.3 in (1070mm)
Overall Length: 35.0 in (890mm)
Flying Weight: 43.4 oz (1230 g)
Motor Size: 480-size 960Kv Brushless Outrunner (installed)
Radio: 4-channel (minimum) DSM2 or DSMX transmitter required
Servos: 4 digital servos (installed)
Prop Size: 10 x 8 (included)
Speed Control : 30-Amp Pro Switch-Mode BEC Brushless ESC (installed)
Recommended Battery: 3S 1800mAh 11.1V LiPo (included)
Flaps: No
Retracts: No
Charger: 2-3 cell DC LiPo balancing charger (included)
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
Link til Smallsize!
- Spektrum™ AR600 DSM2/DSMX receiver, installed
- 4-channel control – throttle, elevator, aileron and rudder
- 960Kv 480 brushless outrunner motor, installed
- E-flite® 30A Pro Switch-Mode ESC, installed
- Servos, installed
- Durable Z-Foam™ construction
- Authentic Red Baron trim scheme
- Machine gun, engine and pilot details
- Includes steerable tail wheel and tail skid
- Includes 3S 1800mAh 15C Li-Po battery
- Includes 2- to 3-cell DC variable rate Li-Po charger
- Compatible with the optional Sonic Combat Module AND the X-Port Adapter (HBZ4020 & PKZ1055 - both required and sold separately).
Flaps: No
Retracts: No
