Så en annonse for denne motoren i et gammelt amerikansk blad, og gikk inn på websiden.
Ikke så aller verst pris heller, $459.00 US for en 120 boxermotor.
Er visst en meget kompakt boxer der eksosgassene er med på å rotere veiva, så den trenger ikke eksospotter.
Noen som har kjennskap til den ?
Technology
Technology
- Twin Combustion Chamber - 1.20 Cubic Inch
Displacement - Patented MCCä Full
Expansion Technology Provides:
- Quiet and Cool Exhaust without a
Muffler
- High Torque, Fly with Scale-Like Propellers - Dimensions: 4.42" High x 4.33" Wide x 5.5" Long - (See FE-120
Drawing) - Engine Weight with Mounting Brackets: 38 oz.
- Power Output: 2.2 HP
- Low Vibration and Smooth Power Flow with Two Power
Pulses Per Revolution - Operates on Glow Fuel with 15% Nitromethane and 18%
Synthetic Lubricants (No Castor Oil) - Fuel Efficient: 1 - 1.5 ounces per minute
- Pressure Fitting on Rear of Engine for Operating
Pulse Type Regulating Pump - Compact Radial Shape Easily Fits Inside of Cowls, No
Bulky Muffler to Hide - Engine Mount, Fox R/C Long Glow Plugs, Spinner,
Exhaust Tube and Tools Included - One Year Warranty
- Thrust Test Results:
Sound at 3 meters
with open exhaust (No Muffler!)
Propeller | Propeller Mfg. |
RPM |
Thrust |
Decibels |
18 x 10 | Moki | 6900 |
14.0 lbs. |
95 dB |
18 x 10 | Zinger | 6200 |
14.0 lbs. |
95 dB |
15.5 x 12 x 4 Blade |
APC | 6400 |
12.5 lbs. |
96 dB |
APC | 6300 |
12.5 lbs. |
92 dB* |
16 x 8 x 3 Blade | Graupner | 7300 |
12.0 lbs. |
96 dB |
17 x 10N | APC | 7000 |
12.0 lbs. |
96 dB |
16 x 14 | APC | 6400 |
11.0 lbs. |
94 dB |
17 x 12N | APC | 6600 |
10.5 lbs. |
96 dB |
