Flate altså!!!
Enda mer man MÅ handle inn!
Kommer i butikken snart
RCF Turbo Crack Beaver EPP Kit - elefun.no - Radiostyrt hobby
Modellen kommer som byggsett med all hardware inkludert, men uten elektronikk. Benytter standard indooroppsett eller litt tyngre for utendørsflyving.
Introducing the Crack Turbo Beaver!
The Crack Turbo Beaver represents the ultimate in RC fun! Equally at home in bush style flying and extreme 3D, the Crack Turbo Beaver is also surprisingly precise and offers unparalleled durability. The huge EPP tires easily roll over gravel, dirt, rocks, tall grass, and other airplanes. The unique X-shaped fuselage design adds scale looks in the air as well as high stiffness with no need for additional carbon bracing, while the rolled cowl and canopy add to the scale outline and lend tremendous strength to the front of the aircraft.
Designed and developed by Twisted Hobbys team members Chris Jewett and Cody Wojcik, the Crack Turbo Beaver takes the extreme design philosophy that produced the renowned Crack Yak, Crack Pitts, and Crack Laser and gives the Crack treatment to the famous DeHavilland Turbo Beaver bush plane. RCFactory adds their world-class manufacturing techniques and the highest quality EPP foam available. The result is just about as much fun as you can have with an RC airplane! Harriers, hovers, precise knife-edge, rolling harriers, flat spins, snap rolls, and other high-performance aerobatics compliment the traditional loops and barrel rolls you would expect from a high-wing plane. The high wing placement means that the Crack Turbo Beaver is also very stable, and makes a great beginners aircraft, or just lazily cruising around the back yard. Of course, being nearly indestructible means you can fly between trees, spot-land on your picnic table, and try other crazy things that youd never do with a balsa airplane.
Equipped with four 5-gram servos, a 2s-3s 350-650mah battery, and 19-26 gram motor, the Crack Turbo Beaver is exceptionally versatile and will fly well on a wide variety of equipment and CG placements. Of course, Twisted Hobbys keeps everything simple as always with a proven plug-and-play power combo that provides great performance at a reasonable price.
Pair your Crack Turbo Beaver with any computerized 5+ channel radio and enable flaperons and spoilerons for even more fun and capability! Near-vertical stalled descents with the spoilers up, low-speed scale flying with the flaps down, and super-tight loops with the flaps mixed to the elevator add even more depth to the CTBs repertoire.
Vingespenn 880mm
Lengde 800mm
Vekt Opp til 230g
Servoer 4stk 4-9g
LiPo 2-3S 350-650mah
Motor 120W
Vingespenn 880mm
Lengde 800mm
Vekt Opp til 230g
Servoer 4stk 4-9g
Motor 120W
