Failsafe på spektrum AR 7000 motaker?
  • kjella
    • Feb 2007
    • 1030
    Kom pluselig på noe her!!
    Er det en failsafe på ar 7000 motakeren??
    og hvordan setter jeg opp eventuelt en slik failsafe
    Kunne jo vært greit å brukt den hvis den var der??
    TREX 600N FBL 3G align.
    jr11x:--))
    http://sokndal-modellfly.com/
    AR7000 har kun vanlig "SmartSafe" men AR7100 og AR6255 har i tillegg til "SmartSafe" en mer avansert "Preset Failsafe"
    SmartSafe
    This type of failsafe is recommended for most types of helicopters.
    When the transmitter and receiver are turned on the receiver connects
    to the transmitter and normal control of all channels occurs. If loss
    of signal occurs, SmartSafe drives the throttle servo only to its preset
    failsafe position (low throttle) that was set during binding. All other
    channels hold their last position. When the signal is regained, the
    system immediately (less than 4 ms) regains control.
    Programming SmartSafe
    During the binding process the bind plug is left in throughout the
    process and is removed only after the receiver connects to the
    transmitter. After the connection is made, confirmed by operating
    the servos, the bind plug can be removed. The receiver is now
    programmed for SmartSafe.
    Preset Failsafe
    When the transmitter and receiver are turned on and after the receiver
    connects to the transmitter and normal control of all channels occurs,
    if loss of signal occurs preset failsafe drives all servos to their preset
    failsafe positions. Some pilots prefer this method but normally
    SmartSafe is recommended for helicopters. When the signal is
    regained, the system immediately (less than 4 ms) regains control.
    Programming Preset Failsafe
    During the binding process the bind plug is inserted in the bind
    port, and then the receiver is powered up. The LEDs in each receiver
    should blink, indicating that the receiver is in bind mode. Now before
    binding the receiver to the transmitter and with the receiver in bind
    mode, remove the bind plug. The LEDs will continue to blink. With
    the control sticks and switches in the desired failsafe positions, bind
    the transmitter to the receiver by putting the transmitter/module into
    bind mode. The system should connect in less than 15 seconds. The
    receiver is now programmed for preset failsafe.
    Note: Failsafe positions are stored via the stick and switch positions
    on the transmitter during binding.
    Last edited by Quadrocopter; 06-10-10, 20:52. Reason: Kopierte feil failsafe info ...
      Nå ligger det riktig failsafe info i tråden...... copy/paste og feil på feil
