Kom pluselig på noe her!!
Er det en failsafe på ar 7000 motakeren??
og hvordan setter jeg opp eventuelt en slik failsafe
Kunne jo vært greit å brukt den hvis den var der??
TREX 600N FBL 3G align.
jr11x:--))
AR7000 har kun vanlig "SmartSafe" men AR7100 og AR6255 har i tillegg til "SmartSafe" en mer avansert "Preset Failsafe"
SmartSafe
This type of failsafe is recommended for most types of helicopters.
When the transmitter and receiver are turned on the receiver connects
to the transmitter and normal control of all channels occurs. If loss
of signal occurs, SmartSafe drives the throttle servo only to its preset
failsafe position (low throttle) that was set during binding. All other
channels hold their last position. When the signal is regained, the
system immediately (less than 4 ms) regains control.
Programming SmartSafe
During the binding process the bind plug is left in throughout the
process and is removed only after the receiver connects to the
transmitter. After the connection is made, confirmed by operating
the servos, the bind plug can be removed. The receiver is now
programmed for SmartSafe.
Preset Failsafe
When the transmitter and receiver are turned on and after the receiver
connects to the transmitter and normal control of all channels occurs,
if loss of signal occurs preset failsafe drives all servos to their preset
failsafe positions. Some pilots prefer this method but normally
SmartSafe is recommended for helicopters. When the signal is
regained, the system immediately (less than 4 ms) regains control.
Programming Preset Failsafe
During the binding process the bind plug is inserted in the bind
port, and then the receiver is powered up. The LEDs in each receiver
should blink, indicating that the receiver is in bind mode. Now before
binding the receiver to the transmitter and with the receiver in bind
mode, remove the bind plug. The LEDs will continue to blink. With
the control sticks and switches in the desired failsafe positions, bind
the transmitter to the receiver by putting the transmitter/module into
bind mode. The system should connect in less than 15 seconds. The
receiver is now programmed for preset failsafe.
Note: Failsafe positions are stored via the stick and switch positions
on the transmitter during binding.
Reason: Kopierte feil failsafe info ...
