Det her ser ganske rått ut. 6S på en 450, ready to run
Elefun har den på lager nå, og jeg tror faktisk de er en av de første i verden.
Løp å kjøp Align T-Rex 450L DOMINATOR Super Combo - elefun.no - Radiostyrt hobby
Align setter en ny standard i 450-klassen med 450L Dominator! Her kombineres 6S LiPo med kraftig motor, kraftig ESC og 36cm blader, dette gir en 450 med overlegen effekt og stabilitet!
Dette Super Combo-settet leveres med servoer, motor, regulator og all nødvendig mekanikk.For å komplettere trenger man batteri, lader og sender med mottaker.
The internationally popular T-Rex 450 has long been a trend setting helicopter, every enthusiasts probably has owned at least one. It is the ideal model for beginners as well as experts practicing advanced maneuvers. Now the T-Rex 450 evolution continues, as Align drops another shocker into the market; with even more innovative designed incorporated, the brand new T-Rex 450L Dominator.
T-Rex 450L reverses the common impression people have on T-Rex 450, with material integration technology utilized on side frame design, and has features previously found only on larger models, such as battery mounting rails, top mounted motor, 700E DFC type main bearing block with integrated servo mounts, forming striking resemblances to larger contest grade models. The newly added frame reinforcement plates not only improves helicopter?s overall rigidity and anti-torsion characteristics, the beautiful red anodizing also creates highly pleasing aesthetics, further exhibits the T-Rex 450L?s attractiveness and exclusiveness. In addition, the T-Rex 450L cleverly expands on the core concepts of T-Rex 450 Pro designs, to carry on the heritage of its mature design of excellence.
Equipped with the DFC flybarless head assembly, paired with newly designed 3D specific 360 3G main rotor blades that are both stable and agile, improving anti-torsion characteristics and power output during flight, resulting in even better flight stability. Based on 6s voltage, the 460MX (1800KV) motor is tailor made for the T-Rex 450L DOMINATOR. When paired with RCE-BL45X brushless speed controller, the motor has superior efficiency, high power output, extreme torque, and low current, low temperature. As a totem to the 850MX Dominator motor, The 460MX shares the same extraordinary pedigree. Brand new DS430M servos controls the swashplate, with feature such as improved torque and speed, along with double bearing support, resulting in minimal deadband and better longevity.
With cutting edge design concepts and top grade electronics, T-Rex 450L Dominator surpasses traditional flight performances with higher stability, extreme power, superior control feel, yet maintains the convenience of smaller size. The T-Rex 450L Dominator is a model not to be missed!
- Length: 705mm
- Height: 205mm
- Width: 110mm
- Main Blade Lenght: 360mm
- Main Rotor Diameter: 804mm
- Tail Rotor Diameter: 171mm
- Motor Drive Gear: 11T
- Main Drive Gear: 121T
- Autorotation Tail Drive Gear: 106T
- Tail Drive Gear: 25T
- Drive Gear Ratio: 1:11:4.24
- Weight(w/o power system): 730g
Standard equipment - 3GX Flybarless System X 1 set
- RCE-BL45X 45A Brushless ESC X 1
- 460MX Brushless Motor(1800KV) X 1
- 360 3G Carbon Fiber Blades X 1set
- DS430M Digital Servo X 3
- DS525M Digital Servo X 1
