Spitfire ARF Composite
    Fikk en slik i hus for litt siden. Ny produsent med komposittbygge og ihvertfall et halvt øye for skal. Modellen er 205 cm vingespenn, kompositt vinger og kropp, cockpit, el understell ++
    Den skal til lagring foreløpig siden det er for mye prosjekter i gang men tror det blir en fin warbird på sikt.
    Kvaliteten ser rimelig bra ut. Skulle gjerne sett skjulte ror etc men de har ihvertfall fått til ganske fine hengslinger med tight passform.
ID:	637107Click image for larger version
ID:	637123Click image for larger version
ID:	637124Click image for larger version
ID:	637125Click image for larger version
ID:	637126Click image for larger version
ID:	637127Click image for larger version
ID:	637128Click image for larger version
ID:	637129Click image for larger version
ID:	637130Click image for larger version
ID:	637131Click image for larger version
ID:	637132Click image for larger version
ID:	637133Click image for larger version
ID:	637134Click image for larger version
ID:	637135Click image for larger version
ID:	637136Click image for larger version
ID:	637122Click image for larger version
ID:	637121Click image for larger version
ID:	637106Click image for larger version
ID:	637108Click image for larger version
ID:	637109Click image for larger version
ID:	637110Click image for larger version
ID:	637111Click image for larger version
ID:	637112Click image for larger version
ID:	637113Click image for larger version
ID:	637114Click image for larger version
ID:	637115Click image for larger version
ID:	637116Click image for larger version
ID:	637117Click image for larger version
ID:	637118Click image for larger version
ID:	637119Click image for larger version
ID:	637120Click image for larger version
  • ole.foll
    • Apr 2005
    • 1043
    Gratulerer! Den så utrolig flott ut til å være en ARF. Hvilke fabrikat er dette, og hvor får man tak i en slik ?
    Ole Kr Follstad
    EF Extra 300 60"
    EF Extra 300 104" Eme120
    GB Yak 55 2,2m, Dle55RA
    ESM Bearcat, NGH 38cc
    Phoenix p51D Mustang, Dle55
    Phoenix K8b, 1:2,5 6m
    Hangar 9 Piper cub 1\4
    Ask 21 1:3 5,7m helkompositt
    • chewbaca
      • Jul 2006
      • 758
      Ser jo ikke gærn' ut den. Men kanskje tidlig å få et inntrykk av før etter du har satt dem sammen
      Jørn Kaasbøll
      Scale Warbirds of Norway
        Kan ihvertfall si at støpekvalitet og generell utførelse er rimelig bra. Men så er det en annen prisklasse enn feks ESM også...
        Ikke helt oppegående hjemmeside men ganske nystartet firma som kommer med flere warbirds fremover.
        Blir dessverre ikke montering på en stund, har bare NOEN prosjekter som må bli ferdig, TF Thunderbolt custom, CARF Thunderbolt og en ESM Dora med diverse modifikasjoner....++
        • ole.foll
          • Apr 2005
          • 1043
          Takk for link. ER understell fra samme produsent?
          Ole Kr Follstad
          EF Extra 300 60"
            Ja, uvisst hvordan det virker foreløpig... Alt leveres. Cockpit, spinner (2 eller 3 bladet) og understell, legger og hjul
            • ole.foll
              • Apr 2005
              • 1043
              Høres ikke gæærnt ut Er el understellet med i kitet eller må man kjøpe det itillegg?
              Ole Kr Follstad
              EF Extra 300 60"
                Kan kjøpe litt rent og kjøpe alt i tillegg
                • ninja
                  • Jul 2006
                  • 44
                  Ligner litt på den som Hobby king hadde i sitt sortement en kort stund tidligere i høst.Den har samme løsning på vingen som en Texan som de har enda.Jeg har en sånn Texan,jeg tenkte å bytte den trestaven til høyderoret,detser litt "billig"ut synes jeg.Den der har samme trestav ser jeg.
                  • ela
                    • May 2007
                    • 51
                    Alltid artig med nye prosjekter. Aldri sett så mye treverk før i en compositkropp Store ror Apropo trestaver eller andre lange staver for roroverføring så kan de settes i uhygggelig store svingninger pga vibrasjoner fra motor/propell. Tretthetsbrudd i gjengerparti/linker kan skje. Ikke spør hvorfor jeg sier det...
                      Trestaver skal ut. Tror ikke det er den HK tok inn.
                      Det er enkelt kompositt /støpt skinn men ikke ala 3D skal ikke veie en dritt herex oppsett men beregnet for spant og struktur
                        HK solgte Vantex sin spitfire mener jeg. http://www.fuyuanrc.com/dept.asp?id=161&mfr=135
                          Å snikbrite?
                            Kineserne lager alt vettu
                            • SmurfAir
                              • May 2013
                              • 1629
                              Grattis!
                              Ser fin ut den der, jeg likte den matte finishen på den.
                              Hva er det lille kortet merket med "Retract Conversion"? spenningsregulator eller en sequencer?
