JR's 2.4-systemer er basert på Spektrum's teknologi, så jeg vil tro de holder seg innenfor de samme rammene. Spektrum er fritt i salg og lovlig i bruk etter det jeg forstår, så jeg tviler på at det kan bli noen vesentlige forskjeller mht JR's modeller.
Jr Spektrum X9303 2.4ghz
den engelske importøren av JR radioer er ikke like sikker på at alt er ok med amerikanske JR radioer selv om de er CE merket, sjekk denne linken:
et lite klipp fra innholdet:
sitat:"
The X9303 version that is now available in the USA is allowed up to 500mW of RF with an effective radiated power (ERP) of 1W. (The ERP takes into account the gain of the antenna fitted). The European version must abide by the European regulations (EN 300-328 ) which limits the power output to 100mW ERP but because the Spektrum DSM system uses Direct Sequence Spread Spectrum a limitation of a Power Spectral Density not exceeding 10mW/MHz also applies.
What effect this will have as a direct comparison between the US version and the UK version is at the moment unknown but anticipate a reduction in range.
Be aware that bringing in the X9303 from the USA means that your insurance will be invalid should anything happen as it does not meet the European Regulations. The X9303 manual does show the CE mark BUT this does not mean it actually is.
This is a failing of "cut and paste" from one manual to another. Horizon/Spektrum have admitted that the DX7 marketed in the USA is incorrectly marked as CE approved." sitat slutt
Her er en Produkt bulletin fra Horizon USA om Spektrum
Spektrum DX7 Product Bulletin
It has been brought to our attention that some Spektrum DX7 transmitters and manuals sold to US retailers
may have been mislabeled regarding compliance with European Union broadcast regulations.
Manuals for Spektrum DX7 transmitters sold in the USA indicate that the DX7 currently meets European Union
power-output standards. While units intended for sale in Europe meet EU output standards, this icon also
appears in the manuals for units intended for sale in the US only. DX7 transmitters that are sold for
use in the US exceed the power limits in place in the European Union. Running changes are being made to
remove this icon from units and manuals that do not meet these stringent standards.
To ensure you comply with broadcasting standards in your area, we are recommending you
purchase your DX7 from within your specific region.
If you are an EU consumer and have purchased a radio from a retailer outside the EU prior to this
notice and you suspect that your DX7 does not comply with the EC specifications, please contact
Horizon Hobby UK’s service centre. If necessary, they will arrange for the re-programming of
your radio to the correct EC specification.
For further details please contact Horizon Hobby UK on sales@horizonhobby.co.uk
or telephone (0)1279 641097.
finnes her
"If you are an EU consumer and have purchased a radio from a retailer outside the EU prior to this notice and you suspect that your DX7 does not comply with the EC specifications, please contact Horizon Hobby UKs service centre. If necessary, they will arrange for the re-programming of your radio to the correct EC specification."
Med andre ord: hvis man kjøper en 500 mW, CE-feilmerket DX7 i USA, for bruk i europa etter at denne artikkelen ble skrevet (14.09), vil man ikke få hjelp med omprogrammering av utgangseffekten på DX7 radioen?
Men det står ikke noe om at de har gjort den samme feilen ved merking av JR 9303 som på DX7.
Merket bak på "morsan" sin JR 9303 og manualen lastet ned fra Horizon viser CE-merkingen og det står i manualen: "FCC ID: BRWDAMTX10
IC: 6157A-BRWDAMT..... .....The following countries associated regulatory agencies recognizing the noted certifications for this product as authorized for sale and use are:
USA Canada Belgium Denmark France Finland Germany Italy Netherlands Spain Sweden UK Ireland Australia".
På nevnte FCC kode fant jeg testdokumentet, som viser målt effekt 128 mW. Mye annet interessant der for spesielt interesserte:
Sjekket dette med utgangseffekt med Horizon:
"Martin,
Thank you for your recent e-mail. The output on the Radios has always
been around 100mw. The early DX7's had some issues with being to
powerful but the X9303 2.4 that was just released should meet all Euro
standards for power output.
I hope you find this information useful. If you have any further
questions, please reply to this e-mail give us a call at 1-877-504-0233.
Thanks,
Daniel
Product Support Team Member
Horizon Hobby Distributors
..."Comment
En enkel og grei rute rundt problemet må vel da være å kjøpe en Graupner MX22 eller MX24 med IFS (Graupners navn på det 2.4 hHz systemet de har kjøpt fra XPS) modul og tilhørende mottager. Da får du et system som garantert er tilpasset EU, du får en mere fleksibel og ryddiger SW i senderen, og et 2.4GHz system som etter min ringe forstand er mere robust.
Har anskaffet modul og mottager til min MX 22 for å teste greiene, ikke mye testing så langt, da flyværet sist helg ikke var til å bli imponert av.
For mere info, se her :
Høres bra ut, men løsningen er vel ganske nøyaktig dobbelt så dyr som JR X9303 (om man ikke har Grauper fra før) og "Instead of settling for a 2.4GHz module adaptation to accomplish spread spectrum capability, JR has incorporated DSM2 as an integral feature of the X9303 2.4. Consequently, theres no added processing time. And in addition, other exclusive features of DSM2like ModelMatch technology that prevents wrong model lossesare also preserved".
Men har man en haug med 35MHz mottakere er det kanskje fornuftig?Comment
Leste newsletteret til Graupner å ble litt imponert. Nå liker ikke jeg å være nødt til å bruke antennene som er fast på mottagerne og utvalget av mottagere er ikke det beste, men dette forandrer seg sikkert.
Det som imponerte meg mest var at Graupner/IFS faktisk allerede har toveis kommunikasjon og FHSS (FrequencyHoppingSpreadSpectrum). Dog skifter de bare frekvens hvis interference oppstår. Men at de kan ta i bruk alle tilgjengelige kanaler om nødvendig er imponerende. Om de bruker spread spectrum er usikkert kanskje
De skriver ikke noe om latency, men det tipper jeg Ola finner meget raskt utav!! Vi venter Ola. Her kom det en halvmeter snø.....Comment
Men dersom det i praksis er samme sender som DSX9 ( Samme utgangseffekt)kan det vel ikke gjøre stor skade ved å bruke en slik, selv om den ikke er spesifikk godkjent for Norge?
Med dagens lave dollarkurs vurderer jeg en 9303 jeg også.------------------
PA Bad Boy med ASP46
E-Flite Taylorcraft
T-rex 450Sport
Cessna Cardinal on floates (EPP)Comment
Nå tok jeg valget og kjøpte meg julegave (som dog ble åpnet litt tidlig).
Kjøpte en X9303 med CE merking og har brukt den i følgende fly:
- AR6100 i indoormodell depron fungert fint uten glitch dog aldri flydd langt unna.
- AR6100 i mini DLG. Fungert fint. Karbon kropp, så antennen ble lagt ut i nesten sin helhet. Ikke flydd langt unna enda.
- AR7000 med 1 ekstra antenne (motsatt side av heli) i Joker2 10s elektrohelikopter. Fungert fint så langt. Ikke flydd langt unna men over is
- AR9000 med 1 ekstra antenne i Adrenaline 2M 10s elektromodell. Fungert fint så langt og flydd temmelig langt unna og over is. Skoleflydd med en tilkoblet 9303 også fungert fint.
- AR9000 med 1 ekstra antenne i seilfly Pike Perfect helkarbon med glassfiber canopy. Antenner "i" glass canopy. 5-600m rekkevidde safe i ca.100m høyde. Ikke helt bra enda. Har opplevd 2-3sek borte flere ganger. Rekkeviddetest med glitchteller viser godt innefor anbefalt.
- AR9000 med 1 ekstra antenne i seilfly Pike Perfect helkarbon med glassfiber canopy. Antenner "i" glass canopy. Litt annerledes montering enn i den forrige. Ikke hatt glitch enda, men må teste mer. Foreløpig vært på 8-900m i 100m høyde uten problem. Rekkeviddetest med glitchteller viser godt innefor anbefalt.
Foreløpig konklusjon viser at det IKKE kan være skygge for antenner på noen måte. Så om antenner monteres slik at det kan bli skygge (av metallisk materiale slik som karbon/metall) mot sender kan man sitte med ett sikkerhetsproblem. Har opplevd 2-3sek borte. Testing i luften har foregått ved kontinuerlig rorbruk.
X9303 mot nevnte mottagere har rask responstid og ikke noen "latency" slik som rapportert fra andre løsninger.Comment
X9303 er ikke, og vil ikke bli godkjent i Norge. DSX9 er modellen som vil bli solgt i Norge - når den er CE-godkjent.
Dersom du importerer en X9303 fra utlandet/USA, risikerer du å ikke få lov til å bruke denne i konkurranser i Norge. Lokale klubber kan også tenkes å innføre restriksjoner, uten at jeg aner hvordan dette vil bli. Annenhåndsverdien på X9303 er vel også noe usikker...
Mitt råd er å vente på DSX9, og kjøpe fra en norsk forhandler.Last edited by attemann; 08-01-08, 22:24.Jan Olav (joeSpace)Comment
